Good quality aerial cable (90 degree)
15 Jun 2009
Cheshire
Can anyone recommend a good quality aerial cable?
Ive just bought/installed a new Samsung Frame TV (2021) - (the one with a one connect box) and I was having trouble with my aerial cable being a bit crap- Seems to be a little loose and also not great quality which mean the signal strenth was low and not picking up HD channels etc
With a bit of a wiggle it does eventually work but Id ideally like to get a better quality cable to give me the best change of a strong signal
I need something 5m male-male, with one end being a right angle :)
TIA
Most of the stuff you can get online is rubbish. I'd say that even the 'quality' options are dubious. They're vastly over-priced for what they are.
If you have any local aerial fitters, then the decent ones will carry Webro WF100* coax and a selection of straight and 90 degree RF plugs. They can make up a lead for you.
Alternatively, Trust message me and I'll make up a lead to length in either white or black sheath WF100 with the ends you want and post it to you. 1st Class will get to you the next working day.
*If anyone suggests that their RG6 is just as good then give them a swerve. That's the equivalent of saying "all graphics cards is the same, guv' "
