Good Quality Headphones with TV
13 Feb 2006
Cornwall
Hi,
I recently got a new tv, a samsung 55hu7500, its a great tv and I intended on using it with headphones in the evenings to be kind to the neighbours/mrs I have Bose QC25s so think its worth finding a method for high quality output.
I have the tv currently connected with via optical cable to an LG SR906 surround system which unfortunately does not have a headphone socket.
I tried plugging in the headphones to the rear of the tv however the wall mount bracket is in a terrible position and once plugged in the audio output is locked to headphones only so plugging and unplugging every time is out of the question.
does anyone know of a system, ideally wireless, though not essential for overcoming this?
Cheers
Easiest way would be to buy an extender for the socket so its in a easy to get to position you can plug into, would make it less of a bother to plug/unplug all the time and still leave the surround system operational while nothing is plugged into the extender.
Or you could go the other way and get a optical splitter/box (plenty online)
And then:
SPLITTER: http://www.ebay.co.uk/itm/Maxview-2-Way-Optical-Toslink-Splitter-4-Digital-Audio-/230913044958
Optical cable from TV to input of the splitter
1 Optical cable from splitter into surround sound
1 Optical cable from splitter into a optical to 3.5mm adapter http://www.amazon.co.uk/Cable-Tex-TosLink-Optical-Adapter-Adaptor/dp/B003WUHKA8
Then another extension but female to female 3.5 like http://www.amazon.co.uk/3-5mm-Female-Stereo-Coupler-Plug/dp/B003L151AY so you can plug your headphones into it.
More of a work around than anything else, but will work.
Hi,
Thanks but I tried this, unfortunately as soon as the extension is plugged in the tv outputs to headphones only, making it a pain to get the surround sound working.
Hi,
Ah well, don't see why TV's do that, mine doesn't...
Only other option is the switch box I said above then really.
unfortunately that 3.5mm adapter does not convert from optical to analogue, its a good suggestion though and there will be optical to 3.5mm headphones available.
Ok, then get a powered optical to analog converter to go in between instead of the adapter (i have one of those, they work)
http://www.ebay.co.uk/itm/Digital-t...Coaxial-Optical-Toslink-RCA-R-L-/290621292124
So would be
TV -> splitter -> surround
TV -> splitter -> digital to analog converter -> headphones
Its going to be ugly but would defiantly work.
doesn't need to be pretty as will be tucked behind in the wall void
I will order one of those and the cables and give it a go, the only thing I worry about is the strength of the signal when it reaches the surround sound (having gone through a splitter)
Yeah that's the only problem, as long as you use decent cables, shouldn't really be an issue.
And its digital anyway so shouldn't really have a signal loss for being split only 2 times.
Second thoughts it looks like my tv supports bluetooth headphones, perhaps I could get a host box for my QC25s?
That would work.
You would still need the digital to analog converter though and a blue tooth transmitter/receiver (as if you plug directly into the 3.5 port on TV it will mute sound still)
Heres a bluetooth transmitter that should work http://www.ebay.co.uk/itm/Bluetooth...Transmitter-4-TV-PC-MP3-Walkman-/231050769203
Lots of thers online everywhere so plenty of choices
So it would be
TV -> Splitter <- Surround
TV -> Splitter -> Converter <- Bluetooth Transmitter (then pair it to the dongle)
It would all depend if your headphones are compatable with the Bluetooth Transmitter though which I imagine will be abit hit and miss.
Hi, no it seems my tv has bluetooth built in, Ive ordered a bluetooth receiver for £3.99 and will try it, it has an analogue 3.5mm socket so should be able to plug my headphones straight in :)
