Good Quality Surge Protector?
30 Nov 2005
London
Hi,
having just read another post regarding thunder storms and none starting PC's I was wondering what surge protectors people are using. I already have one, which albeit isnt the best ever to grace the earth but it is a surge protector none the less but having just upgraded some much needed components was thinking I should upgrade to a better surge protector. More plugs the better. Don't really need one with fancy lights on it etc but something that does the job. Any specific brands I should look at?
Cheers
B
Brown outs can occur anytime, nothing to do with storms. You said you don't have £100 to spend but how much is your PC and monitor worth?
A PSU can store enough energy to provide a stable output for a few MS but not not surge, spike or prolonged brown out protection. Reason why UPS's exist (or cheaper surge/spike main strips)
You know a surge protector losses the protection after loads of small surges or 1 big surge, well is that the case for UPS too? But with a UPS surges goes into the batteries.
No, it is not the case - the "in" end of the UPS can take huge voltages and currents. Whatever you put into it, it modulates the power.
If a power surge knackers your UPS battery then the UPS isn't dong it's job, the voltage adjustment AVR thing should correct that.
I've always used APC surge protectors and UPS. My second UPS is an APC Backups CS 650VA and cost me £65 new.
