Good rates for CSS ?
rate 25000
cl_updaterate 67
cl_cmdrate 67
cl_interp 0.0<ping> so if my ping was 30 i would have 0.03
I'll try and find other commands that help aswell
I personally have never had the need to change them, never suffered from lag or anything unless my virus checker kicks in or folding@home decides to upload, and i just have a bog standard 1meg connection though i do tend to stay away from servers with a highish ping ie stick to a ping of 50ish or lower.
Am i just lucky or the people that need to change their rates unlucky? I have often seen people complaining about lag and others asking what their "rate" are but tbh i wouldn't even know how to find them out :confused:
You should change your rates. Will get better reg on people. The defult ones tend to cripple performance a lot. I forgot to change mine after a fresh install and played so bad untill I remembered.
