‘Good’ Silent PSU?
26 Feb 2004
Hampshire, England.
Hey guys,
I’m a after a silent or near silent PSU for my Dad’s machine?
Atm he’s only running a 1200 Duron but in the next month or so he’ll be going 64 bit :D
Being old, he’s obsessed with noise in the case, so the quieter the better please :)
It doesn’t need to be too powerful, I’d imagine anything over 400w would be sufficient? And anything with modular cabling would be a bonus – he likes things tidy :rolleyes:
Thanks,
SW.
Seasonic will probably be the quietest and fine for any foreseeable upgrades however they aren't modular. Enermax offer modular PSUs and should be pretty quiet as well so if that is a priority then I'd probably go with the 500w as it is fairly reasonably priced as well :)
430w Seasonic, got mine for £40 and it is an excellent PSU. completely silent and comes with some cable management stuff although isnt modular
Check SPCR fantastic website. :D
The Fortron/Source 300w fanless PSU is supposed to be brilliant. If he's running his system at stock, conscious of sound and doesn't have a power hungry setup it might be a good option. :)
Hope that helps!
Hmm. The Seasonic does look good?
Is it completely quiet, I notice there is quite a large fan on the bottom of the unit? Or is it one of those 'ultra' quiet ones?
I'm currently using a Enermax Liberty 500w and that's quiet, but you can still hear it?
I thought the only true silent PSU's would be the ones without a fan at all?
Thanks guys,
SW.
Well, the fan spins at about 800rpm and is a dual bull bearing yate loon fan, it is probably about 17db which is inaudible over ambient noise.
The Enermax Liberty is quiet too, more than acceptable (quiet purr) It's only 200rpm more than the Seasonic, I would say Enermax higher quality lines (Seasonic has dipped) also enermax is modular and has more connectors/SLI GFX cables etc.
If it's for a htpc get the SS, normal desktop/gaming enermax. If htpc is 6'+ away get the enermax.
