Good static pressure 180mm fan??
1 Jan 2012
Scottish Borders - UK
I have a TJ08 with a stock front 180mm fan.
Curious as to what's about for water cooling with a high static pressure for a fan this size?
Anyone any ideas??
cheers!
The provided SST-AP181 you have is probably the best, isn't exactly a large market for 180mm fans tbh, the only other ones that really ring a bell is the Phobya G-Silent 700RPM 180mm fans, but the SP is bound to be lower.
200mm fans use the same hole spacing (54mm iirc) as 180mm fans, the Bitfenix Spectre Pro 200mm would offer higher static pressure than the AP181. Just have a measure and check you have the space for the extra 10mm either side of the fan for a 200mm.
200's you're fairly limited to either CM Megaflows or the spectre pro's, megaflows for silence, BFSP's for performance.
