good system for £800?
6 Jan 2004
leicester
Intel Core i3 530 Processor, overclocked up to 3.8GHz
Asus P7P55D LE Motherboard
ATi Radeon 5850 1024MB Graphics Card
Xigmatek Midgard Black ATX Case
4GB PC3-10666 DDR3 Memory
24x DVD-RW/CD-RW Optical Drive (Black)
500GB SATA 7200rpm Hard Disk
750watt OCZ PSU
Onboard High Definition Audio
Windows 7 Home Premium 64bit OEM
2 Year Collect and Return Warranty - see bottom of description
Included Peripherals:
23" DGM Widescreen TFT Monitor featuring 1920x1080 resolution
Logitech 660 Cordless Keyboard & Mouse
Logitech S220 2.1 Speakers
this is from another site don't know if i can post it but is it a good price at 800 quid
Seems ok to me, it comes in rougly at build cost if you source the same components from here(or sub if not available).
If you let us know if you have anything already, and what your use will be, we could better advise on your query.
If you are getting an i3 then get a cheap motherboard such as this:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-234-GI&groupid=701&catid=5&subcat=1124
or
http://www.overclockers.co.uk/showproduct.php?prodid=MB-233-GI&groupid=701&catid=5&subcat=1124
The one in your proposed spec is one I would be looking at for the i5 750. No point spending all the money on an i5 750 board when you are only going to have a dualcore cpu.
In fact, I would not be looking at a dualcore cpu anyway. Get an i5 750 or the equivalent amd quad.
I just tried speccing a phenom X4 955, gskill ripjaw 4gb ram, asus M4A79XTD, asus HD 5850, OCZ 600W psu and windows 7.
Got to 700quid without a monitor, speakers, keyboard and mouse.
So gave up.
So gave up.
There is nothing wrong with an i3, just make sure it is paired with a cheaper motherboard like I linked, otherwise with the extra £40-50 on the motherboard you may aswel stump up the extra £50-60 for an i5 750 chip.
thats the spec of the pre built system plus comes with a 2 year warranty thought it was a decent pc considering it comes with all you need
It is a decent price.
Only thing to check is how good the monitor is at pixel refresh/ghosting.
i don't have a desktop at the min using my daughters pink laptop atm lol
i need to update my sig to xbox 360 only
