Good value radiator fans
3 Nov 2014
Newcastle, England
Looking for some new fans for when I FINALLY get my wc loops setup.. Want a good 'bang for the buck' on them and to perform as quiet as possible while pushing/pulling a nice amount of air.
Budget isn't too high and I need say 5 for 2 rads and 1 for rear exhaust and maybe 1 for a bottom intake
I have these on my rads. You need to control them with a fan controller or something though because they are very noisey at full speed. They don't half shift some air though.
PapaLazaru's suggestion also comes in a bundle here so you save a bit of money.
I am so happy you suggested the OCUK fans, I have I think 6 of those, 3 in the PC, 3 sitting on a shelf so they would be my first choice was just curious if there was anything 'better' worth the money, but if not, buzzing haha!
If you already have some of them fans then ya might aswell stick with them, i dont think you would notice much difference changing to another fan in the same price range, you would have to probably wait for some of the expensive fans to come on offer to get a quieter experience.
As long as your using a fan controller you'll be ok with either of them fans, without a fan controller theyre both very noisey.
I have 8 of the OcUK FQ121WC fans and they are great combined with the NZXT Grid+ V2 and they work perfectly. Really good value.
They are Silverstone fans in fairness and can't see OCUK of putting their name on something bad, and for the price I can't grumble think I will have to take the time to set up the fan controller in the Enthoo Luxe properly!
