Good weight loss gym routine?
19 May 2005
Belgium
Hi chaps,
I have just rejoined the gym after a long time of not going and getting seriously out of shape. To put it simply, I need to loose about 7 stone!
So what sort of of routine should I be aiming for, I really want to concentrate on the weight loss but take care of the stretch marks...
I need to know what machines/exercices I should be doing so I can stick to it.
Any help would be great.
Firstly, to minimise the stretch marks and loose skin, make sure you do slow weight loss. Losing too much too fast leaves you looking like a deflated balloon.
Split your time between weights and cardio. I generally do 3 days per week with 30mins of cardio and 30mins of weights.
There's no secret to what exercises will lose most weight. Everything helps. Running is probably the best for fat loss but is torture on your joints if you're too overweight, so the cross trainer is a good compromise. Don't just go to the cardio section and use the same machine for the full 30mins every time you go. You want to mix it up and use every machine.
As for weights, most people split their bodies into concentrating on different areas on different days. I do legs on Monday, arms and upper back on Wednesday and then core muscle groups on Friday. Lean muscle burns more calories per kg than fat so it's a good idea to do weights as it increases your Basal Metabolic Rate.
One piece of advice I was given when I started was to give it your all for the 60 mins in the gym. So many people fall into the trap of "going to the gym" but in reality they're sitting around on the machines looking about the place doing very little. Work up a sweat!
Finally, I found my weight didn't budge until I sorted out my diet. Going on a "diet" is a waste of time. You just want to make sure you're fueling your body with the right things (read the sticky above by Steedie) and create a modest calorie defecit. It's really a sustainable lifestyle change rather than a crash diet that you need.
If you're after weight loss do cardio. This like a rowing machine that exercise pretty much your whole body are ideal. That or swimming.
Running is a bit hard at the moment due to my size but I will give it a go.
The rowing machine is fine, what sort of intensity should I be going at?
So would 15 mins on the bike and 15 mins on the rowing machine be ok at first?
I also do a 15 minute walk to the gym and back.
If you need to lose 7 stone you really need to address your diet.
Exercise helps fat loss, no doubt, but diet is the killer. You can spend a sweaty 4 hours a week in the gym and burn 2,000 calories, but if you cut 500 calories out of your daily diet (which is probably vastly excessive as it is) you remove 3,500 calories a week, just by eating less.
Could you maybe list your current diet (honestly!) on an average day?
We might then be able to suggest simple tweaks and adjustments to improve it.
Diet and excercise is extremely subjective. Ask 100 "experts" and you'll get 100 different answers. Doing your own research is key.
My typical diet over the past 5 years has been typically, 3 good meals a day but with lots of crap in between which is my downfall.
Yesterday I had a 3 egg omlette for breakfast, wholemeal pitta bread with chorizo for lunch and chilli con carne for dinner, does that sound ok?
My main issue is lunch as never know what to have!
Ya doesn't sound too bad. Try and get protein in at breakfast (which you have), and lunch. It keeps you fuller for longer and aids muscle growth/repair.
Cut out the junk in between. Have a banana mid-morning and an apple mid-afternoon or something to stave off the hunger. It also keeps your blood sugar levels at a steadier level throughout the day.
Good to see you have wholemeal stuff in there. When you're having carbs try and ensure they are complex ones, low on the GI scale. They release energy more slowly than white bread etc.
Only other thing is what do you drink? If it's coffee with 4 sugars then it's something you seriously need to address. Likewise with fizzy drinks etc. They're full of sugar and empty calories. Same goes for Alcohol - it's very calorific and full of simple carbs.
Drink many litres of water per day! You'll pee like a racehorse for the first week or so, but after that it'll calm down. Water, and loads of it, is essential for weight loss.
Might be a good idea to keep this as your go-to thread so you can keep us updated with your progress. You'll have good and bad weeks, but the important thing is to make the changes now, stick with them, and you'll see the results in a few months.
Best of luck by the way!
Chorizo is mainly fat, stay away from most red deli meats.
replace with chicken, turkey or tuna.
also try IF (google lean gains), eat for 4 hours in a day and fast for 20, every day. this will in turn help you lose weight and your body gets used to eating very little, so if you do stop IF, your portions will have shrank.
also if you fill your plate up and half way through your meal you feel full, stop eating (overeating is the biggest cause), put the rest of the meal in the fridge to have later on.
willpower, mentality and knowledge are key here, without them being 100%, you will fail.
Your stomach stretches an insane amount, even if you're used to eating little, eating bigger portions is something you are simply used to, for life, willpower is the only thing. Starving yourself kills metabolism, its that simple, the MAIN THING your body does to use energy is build cells, you replace most cells in your body every couple years in total, every single last cell will have been replaced after 7 years(though most multiple times).
Its as simple as this, the less you eat, the less your body uses energy, dropping to little food simply tells your body to burn not much food, useless.
What you want to do is eat everything you need to build cells all day long, every day, and use your body fat as the energy to fuel the process.
Carbs bad, fat/protein good, take a multivit, take extra b-vits(you pee them out so a super uber dooper mega vit b tab is pointless in everything except turning your pee fluorescent, a "normal" b vit in the morning and afternoon is best).
Focus on muscle building in the gym, again, the increase in metabolism after lifting weights is very simply from one thing again, repairing/replacing cells, it takes a lot of energy, and a decent wedge of protein and minerals/vitamins to do.
Nothing wrong with cardio, but cardio is for fitness primarily, its a small amount of calories burned, when weight lifting for the same time will give a bigger weight loss, strengthen joints, etc, etc, which will all at a much later date after having lost a lot of weight, make starting heavy cardio(as fitness is important long term) much much easier.
Think of it this way, a few sets, especially as you start, go a LONG way, every step you run, while overweight, is something the joint isn't really designed for. You're more likely to injure yourself doing heavy cardio, which is a pretty bad morale losing situation when trying to lose weight. LIkewise, long long cardio will leave you feeling hungry and tired, making not eating like normal very hard to cope with. Short, sharp, quick weight lifting leaves your muscles hurting, but less overall tiredness and less of the feeling of the need to eat(IMHO).
Protein shakes are great simply because you can buy a complete variety, both in flavour so you get less bored with your food intake, and in nutritional content, low carb, high carb, good carb, great protein, good vitamins. Protein other than fuel for your metabolism, fills you up, keeps you healthy, and a large chunk of water with it also helps fill you up.
Water is the other key thing, dehydration is bad, you need it to maintain cell building, metabolism, health, flushing out toxins, etc, etc, aswell as filling you up.
Sorry, in terms of gym routine, assuming you have a really low level of fitness(even if not), don't go all out, too long lifting weights isn't helpful, short, sharp, intense. Hell, do 25 mins, focus on one body part and go a few times a week, its easier, you'll rarely feel too tired for only 25 mins, its much less daunting than going for a 90min run every day or two for a year or two, which is tiring, injury inducing, morale sapping, and boring as hell.
Get in, pick a body part, make it hurt, bad, leave, job done. Okay, maybe be a bit more clinical, go on any exercise site and pick a 3 or 4 day split, whatever you can reasonably commit to in terms of getting to the gym, again the shorter the time in there the easier it is to fit in and the less tired you'll be. Earlier on, stick with compound things like squats, bench press, things that use more muscles at ones so you can hit more groups quicker, and ones that hit all the small stabliser muscles, its people who focus on a single muscle, likea bicep curl, who get injuries.
I'm very dubious about this whole intermittent fasting thing. It gets bandied about here quite a lot, but most of it seems to be nothing more than bro-science. All the "supporting" evidence seems to come from amateur fitness freak websites with absolutely no scientific grounding.
Does anyone have a link to a reliable source (medical journal, scientific study etc) that actually supports it?
Read 'Eat Stop Eat'. I'd say its quite the opposite of bro-science tbh.
wall of text
oh god who let you out of football arena
I don't really care about it much myself, I prefer just eating a well balanced diet, and doing exercise. Much simpler!
aye, its what I did 5 months ago, joined a gym for weights and access to some cardio equipment, went 3/4 times a week, stopped using the car, cycled everywhere, weather was perfect for cycling, got my fittest up, got my weight down and just built on from that.
Diet is great apart from alcohol at weekends and the odd cheat meal.
The body will lose weight, you will become faster and fitter if you exercise, its what its designed to do if you fuel and work it correctly.
