3 Nov 2006 at 12:00 #1 tang0 tang0 Soldato Joined 12 Jun 2003 Posts 3,951 As title Must be good with lots of connections and doesnt drop out ie bit-torrent
3 Nov 2006 at 12:51 #2 Avalon Avalon Soldato Joined 29 Dec 2002 Posts 7,748 i'm assuming you are after an ADSL modem ....Either way this will help. You may also want to consider getting a seperate modem with RJ45 out ?
3 Nov 2006 at 12:57 #3 tang0 tang0 Soldato OP Joined 12 Jun 2003 Posts 3,951 Nah im after a router than has a built in adsl modem so i dont need a seperate one, and a router that can have wrt firmware on it
3 Nov 2006 at 18:02 #4 tolien tolien Caporegime Joined 16 May 2003 Posts 25,367 Location ::1 Take your pick from here? Doubt any of them are ADSL routers though, given the WRT54G/GS/GL isn't. Edit: Netgear DG834G's a work in progress (and some of the Linksys ADSL routers)...
4 Nov 2006 at 17:16 #5 tang0 tang0 Soldato OP Joined 12 Jun 2003 Posts 3,951 hmm none are adsl routers :< ive got a DG834GT atm and it just keeps dropping the connection all the time, i need something decent, never happens with my dg834 any other ideas, regardless of what firmware they can do, i just need it stable !
4 Nov 2006 at 18:46 #6 pallys pallys Associate Joined 2 Jul 2004 Posts 1,430 http://wiki.openwrt.org/TableOfHardware?action=show&redirect=toh well if its not on there then you cant do it...
