I need to re-do mine, I have always been No Swearing! at Cable Management, in fact i get so frustrated that my HDD aint even screwed in.
I have an Antec 900-2 case. Any tips?
So, a 900-2 is the one to go for?
I do like the 300 but doesn't have good cable management.
Can the 300 back inner panel be cut to thread cables through?
Lian Li PC-7B?
i know its a pretty big chunk over the budget, but consider this:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-055-SV&groupid=701&catid=7&subcat=1092
after looking into it myself, it has awesome cable management potential.
have you got one now edgey?i know its a pretty big chunk over the budget, but consider this:
Exactly same as PC-7F apart from the front bottom panel
I would go for Lian Li PC-7. Thinking about getting PC-7F with window myself or PC-8 as i can get good price for them![]()
