Goodbye old friend!
16 Oct 2018
So my poor old Enermax Galaxy is giving me the 3 beeps after many years of great service. Fans failing I think. I might give it a good clean to see if that helps but I’m thinking a new 1000w psu..any recommendations?
cheers
S
Good evening Badger!
That PSU has lasted you a while, do you really need another 1000w PSU? Could you system run on something with lower power? You could save a bit of £££ that way aswell :D
Yes, it’s done well. I did over spec when I bought it just to future proof. I’m only running a 2070 super and about 4 hard drives. Not sure what I actually need power wise tbh. I’m going to take the PSU out tomorrow to see how easy a fan replacement will be. Just had a quick look on here and lots of PSU’s are sold out.
cheers
S
cheers
S
Yeah I'd say your PSU could be lower as the new GPU's recommend less power than that, Finding a lot of things in stock lately is a challenge with the whole pandemic, mining etc happening
What are your specs? PSU calculators over-estimate on the basis that it assumes you will use a crap PSU.
Hi
I'm using the following
Asus TUF X99 Sabertooth MB
I7-5820K 3.30GHz
2070 super
Team Group Elite 32GB
Samsung NVMe Solid State Drive
4 x HDDs
Blueray drive
24" Monitor
Cooler master cosmos s, with the big fan on side and about 3 other fans running
Cheers
S
I would buy an 850watt as it will cover you better for future upgrades (unless money is really tight)
New GPU's these days are drawing big power again
cheers
S
just google search psu calculator. pop ur details in and presto. probs around 500w for a 2070. however as grimly says if u want a 3080 in like 2024 when we might actually be able to get them, 750w-850w is best
