goodmans gtvl20w7hd HDTV/monitor will it do 1680x1050 more info inside
20 Apr 2004
Oxford
this in my local suppermarket for around the same price as a dell 2005WFP of the above make and model clamed it had HDMI on it so i did abit of digging a found out the screen can do 1680x1050 , i thought this could be a nice little buy but the only sticking point was the "pc input" after a quick email to goodmans they sent me the PDF manual
it dose the HDMI over DVI (cames with a HDMI to DVI cable) and a normal 15pin DSUB , it shows as it should i could use the dsub and the dvi for the pc input , looking great i though got to a page labled "pc input Preset timing table" with 1 page for the analog dsub and no page for DVI and list the top 4:3 res of 1280x1024 and widescreen res of 1360x768 , do you think i couls still get 1680x1050 over the DVI
