Google Maps issue
18 Oct 2002
Southend-on-Sea
I'm trying to put Google Maps onto a website to show the location of the business. I've gone to Google Maps, put in the postcode and everything looks fine, the marker is exactly where the business is. However, when I copy the link code onto my site, the marker has moved about half a mile away and the postcode in the Address box has changed.
The underlying code still has the correct postcode (SS2 4FA) but the marker is showing as SS2 5. Anyone had a similar problem before or any ideas on what the problem is?
Thanks
Just to confirm, this is the code from Google Maps when you click on Embed:
Code:
<iframe width="425"
height="350"
frameborder="0"
scrolling="no"
marginheight="0"
marginwidth="0"
src="http://maps.google.co.uk/maps?hl=en&amp;q=ss2+4fa&amp;lr=&amp;ie=UTF8&amp;hq=&amp;hnear=Southend-on-Sea,+Essex+SS2+4FA,+United+Kingdom&amp;gl=uk&amp;ei=xR_oS_zUC4OM0gSOkozFBg&amp;ved=0CBcQ8gEwAA&amp;ll=51.552704,0.737225&amp;spn=0.008085,0.022638&amp;z=14&amp;output=embed">
</iframe>
<br />
<small>
<a href="http://maps.google.co.uk/maps?hl=en&amp;q=ss2+4fa&amp;lr=&amp;ie=UTF8&amp;hq=&amp;hnear=Southend-on-Sea,+Essex+SS2+4FA,+United+Kingdom&amp;gl=uk&amp;ei=xR_oS_zUC4OM0gSOkozFBg&amp;ved=0CBcQ8gEwAA&amp;ll=51.552704,0.737225&amp;spn=0.008085,0.022638&amp;z=14&amp;source=embed" style="color:#0000FF;text-align:left">View Larger Map</a>
</small>
As you can see, no mention of SS2 5, only SS2 4FA, so why is it showing the wrong location?
Have you tried using coordinates instead? It's somewhere around 51.55281614204713,0.7385066896677017
Yep, had already tried that but marker is still way out. Weird thing is, if I click on the SS2 5 link in the Address box, it opens up Google Maps and shows the correct SS2 4FA location.
Weird, done this plenty of times before without any problems.
reflux - could do this, but then users won't be able to use the Get Directions link to the business.
I'm trying to find a solution on the Google Maps site but no joy so far.
Cheers guys.
