I'm getting massive interference with my Gorpo hero 3 and external mic that I have running to back of the car.
Does anyone know if I used a balanced cable it would solve it, I read they're less susceptible to interference.
I tried to run it away from the car wiring, but with the amount of electronics in it, I guess it doesn't matter where I route it.
Here's a vid.
https://1drv.ms/v/s!Ai7xsdVc6V9Yg2mAnirtoKxj5ORu
Extension cable that I'm using.
https://www.amazon.co.uk/dp/B007OH6P1K/ref=pe_385721_132454791_TE_3p_dp_1
All works perfectly fine outside of the car.
TIA.
Here's a vid.
TIA.
