got 170 to spend
11 Dec 2005
the mighty hereford
ok youve probably all read my threads about me wanting to go with cheap watercooling. but guess what i have chnaged my mind i am going to go ahead and get a kit no more than 170quid so what kit would be the best to go for.
7 Aug 2004
gurusan said:
Swiftech Apex Ultra...check out OCuk watercooling section
yep is very good, I got the £200 version with all the gubins, cpu runs at roughly the same temp as my xp-120, albiet 200mhz higher with a lot more volts, and my X1900XT is maxed out on the overclock settings in ATI tool, 690 core :D
OP
11 Dec 2005
the mighty hereford
what sort of performance is this going to give me
1x Danger Den Maze3 Lucite Top
1x XSPC R120-S Radiator
1x 120mm Xinruilian Fan
1x Eheim 1048 Water Pump
1x Floppy Bay Res
5ft Danger Den 1/2 inch Hose
8x Nylon Hose Clamps
1x Water Wetter
1x UV Florescent Water Dye
