Rosetta![]()
The way you are encouraging us to play Rosetta, makes me wonder if there is some sort of devious piracy scheme afoot to theive our credits![]()
Set your Community Preferences... heres where you will manage your team selection... if you attached to the projct as a "new user", you will need to select a team here... click "find a team" and in the search keywords box, enter "The Pirate Fleet"... click on "The Pirate Fleet" and it will take you to a team information page... you must click "join this team" to do so... now under the community preferences it will indicate that you are a member of "The Pirate Fleet"...
Set your Community Preferences... heres where you will manage your team selection... if you attached to the projct as a "new user", you will need to select a team here... click "find a team" and in the search keywords box, enter "OcUK - Overclockers UK"... click on "OcUK - Overclockers UK" and it will take you to a team information page... you must click "join this team" to do so... now under the community preferences it will indicate that you are a member of "OcUK - Overclockers UK"...
I think he meant falling.![]()
