Connectivity Labs which gives you a literal plethora of WiFi info and diagnostics from home walkaround survey to stats and other geek-out data. I recall some of this being available in the past but now there's more stuff baked in.
I will be reconfiguring my wifi this eve based on some findings now.
To enable it simply follow:
Go to Wi-Fi:
Go to Wi-Fi:
- Tap three dots
- Tap Intelligent WiFi
- Tap several times on version number at the bottom, this enables Connectivity Labs just below
- Tap Connectivity Labs and you'll find A LOT of interesting data and tools
- Tap WiFi developer options
- Tap Connection Information and you'll see connection speed!
