Got all the parts, just have a question about keeping the same ssd
2 Jun 2014
All the parts came for my new build today. The only things I'm keeping from the old one are the ssd and psu. Now, what happens with windows when I switch the ssd to the new mobo? Can't find a solid answer online. Some say you might have to reinstall others say it will just need reactivating. In either case am I fine just plugging the ssd into the new setup and seeing what happens?
Cheers
It's kind of a catch 22. It SHOULD work with windows on it however you really should be doing fresh windows with a fresh build because it's going to have so many driver conflicts across the board.
Think about it that OS has been set up for your old system in the registry/installs/software/drivers and such. There is no easy way to get this back to it's fresh state so a fresh install really is ideal just to stop any possible conflicts.
Depends on the OS...
Windows 8.1/10 - Should work no problem
Windows 7 - Might work
You'll likely need to activate Windows again.
As above though - Fresh install is always preferred if you can. Driver conflicts won't be an issue.
So I just did the above. It kept getting to around 70% and then it would throw up an error. I tried it a handful of times and it appears that it's partially wiped the drive as it's now saying there's no os detected. It says this everytime I turn it on -
"An operating system wasn't found. Try disconnecting any drives that don't contain an operating system. Press Ctrl+Alt+Del to restart."
If I hook up my dvd drive and put the windows installation disk in will that rectify everything? As in, I can just reinstall windows from disk?
Thanks.
