got screen 1 and 2 mixed up
10 Jan 2007
Warwickshire
can not work my way out of this mess :confused::D
i have got my 1st screen as me tv and my 2nd screen as my monitor, i have set my monitor to primary, but it still shows as screen 2 :confused:
Saying screen one doesn't matter, as meandu said. If you've set the monitor as primary then you're done. You can drag the windows around in the box if you want to change their arrangement, to change how you move the mouse between them.
Also you can right click on the screens in CCC and select swap which will swap the numbers associated with each screen and then rearrange the order by dragging them..
