Got some issues with my Lian li 343b case
2 Sep 2014
Yorkshire/UK
Hi folks
This will be my first post and one that I am really hopeful will have some good feedback/ideas...basically I really need your help!!!
Ok well I recently purchased, slightly cusmomised Lian Li 343B cube case but have run into problems as they are not designed in the same way as a regular case, my first issue is in understanding how to mount and fix internal 3.5" Hdds all the possible storage campartments are too wide unless the hdd is mounted along it's length but then there would be no srew placements to fix it to the case?
The other headache for me at the moment is trying to figure out how to attach the 9 pre installed 3 pin (female) fan connector cables, none of them are over a few cm length so I need a long..maybe 30 cm? splitter cable to a 4 pin molex connector coming from the psu,
I have really been looking for what I believe is what I need but cannot find something which will allow my connect all the fans, even multiple cables do not seem to help
Unless I missed something or overllooked something?
Really need some help and advice guys ......
thx
no comments?, plz guys I'm flummexed with this problem, surely some people in here must have some good ideas, and I orgot to add I also want to use an older hdd 3.5" hdd but my motherboard does not have an IDE socket so whats the best way to use it with my mobo?
cheers
