Hi
I am running Ubuntu/Dapper and when i try and open GEDIT from a terminal it opens ok but i get these messages:
gedit
- using device default
ALSA lib confmisc.c:1107
snd_func_refer) Unable to find definition 'defaults.pc m.subdevice'
ALSA lib conf.c:3493
_snd_config_evaluate) function snd_func_refer returned err or: No such file or directory
ALSA lib conf.c:3951
snd_config_expand) Args evaluate error: No such file or di rectory
ALSA lib pcm.c:2102
snd_pcm_open_noupdate) Unknown PCM hw:0,0
ALSA lib pcm_dmix.c:819
snd_pcm_dmix_open) unable to open slave
Foor your info my sound works ok when playing MP3 or movies BUT i get no system sounds. The sound is onboard sound using nvidia sound drivers which are OSS. I have posted before (in many places) about how to get my system sounds to work but to no avail. However does the above give any clues as i assume that maybe GEDIT is trying to beep or something as it opens but can't.
Any ideas how to fix?
Many thanks
Diss
gedit
ALSA lib pcm.c:2102
Many thanks
Diss
