Not a question but a general recommendation, especially to those considering an expensive, slow and clunky on-camera solution such as the Nikon GP-1. I didn't want to spend £200 on something that'd make my camera less wieldable, but had a lot of difficulty finding which GPS loggers worked well and even more difficulty finding which had software that actually functions properly. The loggers I considered were mostly comparable...similar memory, battery life, and bluetooth should you care for wireless.
I first bought a Globalsat BT-335 for ~£70, and whilst the hardware was nice the software to talk to the logger ('Data Logger PC Utility') didn't function correctly and wasn't capable of directly tagging the photos. locr (bundled free tagging software) complained the GPS log files were incomplete. No go with Microsoft pro photo (another free tagging software) either.
I now have a Photomate 887 (Blumax Bluetooth GPS-4043 Recorder) which cost £44 posted. The software (GPS Photo Tagger) with this works properly under Vista x64, and tags my D90's .NEF files with no issues. Quick, easy and cheap.
I'm not claiming the above is massively enlightening, but it would appear GPS loggers for the purpose of photo tagging is a bit of a minefield. It didn't help that the recommendations I could find were all for models already discontinued, and something as proprietary as Nikon's camera-specific RAW format is difficult to confirm support for. Compound that with a 64bit OS and things get very sticky. Please share any further experiences and recommendations.
