30 Apr 2009 at 21:02 #1 NiCkNaMe NiCkNaMe Soldato Joined 17 Jul 2005 Posts 3,193 Hi Guys, Does anyone have any personal reccomendations for GPS walking software to suit windows mobile? It's for my dad and don't really have a clue bar TomTom. Thanks
30 Apr 2009 at 21:05 #2 Over Clocker Over Clocker Man of Honour Joined 17 Oct 2002 Posts 9,712 Location Retired Don Google maps?
30 Apr 2009 at 21:08 #3 NiCkNaMe NiCkNaMe Soldato OP Joined 17 Jul 2005 Posts 3,193 Will give it a whirl, didn't think to consider that which is strange since i've used it numerous times on my mobile :s Cheers. Is there any decent software that incorporates ordnance survey maps? It's a bday present so I can't ask him much and i haven't really got a clue
30 Apr 2009 at 21:41 #4 Tomsk Tomsk Soldato Joined 18 Oct 2002 Posts 5,238 Location Overground, underground.. www.anquet.co.uk They supply the entire OS maps suitable for PC and portable devices. £165 for UK or you can buy single maps or regions.
30 Apr 2009 at 21:49 #5 Scottland Scottland Soldato Joined 18 Oct 2002 Posts 15,713 Location North Wales There's Memory-Map too I think
30 Apr 2009 at 21:50 #6 Uhtred Uhtred Soldato Joined 18 Oct 2002 Posts 6,372 Location Bedfordshire I used a trail of http://www.viewranger.com/phonesupport.php and it looked very good. You can just buy the section of maps you want which should work out cheaper. ignore - forgot the windows part Last edited: 30 Apr 2009
30 Apr 2009 at 23:16 #7 NiCkNaMe NiCkNaMe Soldato OP Joined 17 Jul 2005 Posts 3,193 Cheers guys... I like the look of anequet due to the modular maps Thanks.
30 Apr 2009 at 23:49 #8 Burnsy2023 Burnsy2023 Man of Honour Joined 17 Nov 2003 Posts 36,749 Location Southampton, UK Tomsk said: www.anquet.co.uk They supply the entire OS maps suitable for PC and portable devices. £165 for UK or you can buy single maps or regions. Click to expand... That's impressive.
1 May 2009 at 03:23 #9 dbmzk1 dbmzk1 Soldato Joined 28 Oct 2002 Posts 9,227 Location Stockport / Manchester I'd just use Google Maps.
1 May 2009 at 10:22 #10 Uhtred Uhtred Soldato Joined 18 Oct 2002 Posts 6,372 Location Bedfordshire dbmzk1 said: I'd just use Google Maps. Click to expand... not enough detail on there for walks
