GPU AIO pump control
11 Jun 2021
Brighton
Hi Guys
Recently got my hand on a Gigabyte RTX 2080 Super Waterforce and would like to know if it’s possible to control the pump speed?
I can’t seem to find an option for it in Aorus Engine or Speedfan.
I’m guessing the pump connects to the GPU pcb so I wouldn’t be able to do it via Bios either.
Anyone have any suggestions?
From what i've seen online, the pump speed is locked and can't be changed, only the fan speed can be altered. Why did you want to change it?
I would like it to run at 100% like my CPU AIO.
I find the liquid cools faster when moving round the rad quickly.
Ah unfortunate then, maybe you might be able to short the pump if you wanna risk it and force it to run at 100%. Maybe search around and see if there's a bios that does the same thing? Yeah a faster pump will make it run cooler but at the cost of sound.
if it’s going to be that complicated then I’ll probably buy a different block to go on the PCB. Don’t like the AIO on this anyway looks nasty
thanks for your advice
If the GPU pump is PWM you can simply disconnect the PWM wire so that only the power and ground is connected and it will run full speed all the time
If its DC controlled it may not be as easy though but you could just disconnect it from the card and supply it with 12v directly from a molex or pump header...
