GPU and CPU blocks?
9 Aug 2010
Uk
Just wondering what is a good CPU block?
Also I have a gigabyte 770 wind force card will I need to use a specific GPU block or will any of the standard ones fit?
As for CPU block I've heard good things about ekwb and xspc ones, I think a lot of it is down to personal preference on looks, I'm getting the xspc raystorm only for that reason.
You should hit up www.coolingconfigurator.com to check for the GPU block, I know my 670 windforce uses a 680 pcb so I have to get the 680 block - Adam
