GPU Brace/Anti Sag Device
24 Mar 2018
Brighton
Anybody got any thoughts on Anti-Sag devices for long cards, Asus Strix in particular.
I've seem some on newer cases etc, just concerned over a period the sag may cause fan problems.
I missed those when I was looking, I needed to look past the Leg Braces :D I like the Horizontal ones but not a big fan of the logo. Not conviced they will keep the card straight either.
chunky felt tip cut to size, cover with vinyl wrap with the color of your choice. pop it below your card towards the end making sure that it doesn't interfere with any fans. you would never even notice it was there. done the same for all of my cards. works every time
Jayz2cents video is worth a look, might save you some money....
Sorry thats why I can't take that Guy seriously.. erm 2:00
https://mnpctech.com/gpu-support-bracket/
Great Idea I'll take a look at that.
Lego bricks, pick the colour to match your build, proceed to build a pillar :D who doesn't like messing with Lego
I can't fathom that. Any pics online so I can understand it?
I know, but it wouldn't survive the trip back and forth to Uni though :D
You would need a mid-tower case (with shroud) because of the height.. but the idea would work on a Asus Strix GTX 10xx card because you would need to catch the straight/flat bit on the end of the card with the pointy end removed and a slight L shape taken out so It didn't slide into the fan :eek:
