Was playing a game and my PC shut down after a sparking noise, wouldn't turn back on.
I then tried a different PSU plugged into the motherboard and the PC creates a spark on the GPU and shuts down after a second. Note that the GPU is not even plugged into the PSU. https://imgur.com/a/6FUzRGS
What could be causing this and how can I fix it?
a quick google shows loads of instances of it, top google result:
, the only problem I now have is that I can't figure out why the pc wont boot without the GPU installed if that is where the problem is.
