Hello.
I have a GPU buzz issue that sounds a lot like what this person had:
Had the same problem on two different GPUs. It's there no matter the frame rate as long as the card is under load and one particular characteristic is that it's actually picked up by my headphone amp. It comes precisely from where the power cables are connected, not the coils since the chokes are much closer to the GPU and there is pretty much nothing on that end of the RX Vega's PCB.
Tried changing the PSU, motherboard (although with an old identical one from a previous problem of mine) and power outlet to no avail.
It is plugged on two different pci-e cables as recommended.
Any ideas?
Thank you for your time.
Any ideas?
