- 30 Sep 2006
- Midlands, UK
Hi all,
My rig (see sig) currently has a 7950 which meant i had to slightly 'customise' the front panel of the case. You can't see any difference from the outside so all is good.
However, i want to do a new build using the same case but with a GTX 790.
I've found a couple of 790's that are less than 10". The Innod3D is just over 8" and the EVGA is about 9.5".
However that was doing research external to OCUK shop.
The cards in the OCUK store don't show length specs (hint, would be a good idea guys), so i'm a little dubious about the exact specs before buying.
Can anyone confirm a short 970 in the OCUK that i could go for?
