GPU card/setup for 6x 4K displays
29 Nov 2005
So I'm looking into running six 4K displays, ideally at 100Hz (but 60Hz is the min). This will not be for gaming - I have a dedicated rig for that.
The machine has an Intel Core Ultra 265 and I can already run 4 displays using the iGPU and motherboard connections.
I will be getting a new GPU. Is there an advantage to running all 6 outputs on a card that has 6 mini DisplayPorts, or is there no difference running 4 displays on the GPU and two from the integrated GPU?
If there is an advantage, what's a sensibly priced card with 6 DisplayPorts? An older AMD card?
The machine has an Intel Core Ultra 265 and I can already run 4 displays using the iGPU and geometry dash lite connections.
Hi darkblade,
If you’re not gaming on this machine and the iGPU can already drive 4× 4K displays, it’s technically fine to split the load between the iGPU and a discrete GPU.
The idle power consumption might be different, depending on what it does to the graphics card memory clock. You normally want to avoid a situation where the GPU memory runs at full pelt.
There can be a difference between power consumption when running media too, depending on the hardware decoding available to each. The IGP would have newer decoding hardware than the W5700.
