GPU Cooling advice needed!!!!
25 Jan 2006
Gateshead, Newcastle
Okay so i have a project coming up soon and its going to be a small form factor in the Lian Li V300 case.
i wanted to use a full GPU block for my graphics cooling, but have realised that it wont fit (without more modifications resulting in me losing a hard drive bay)
so i was wondering if something like the Maze 4,5 or the Swiftech MCW60 could be mounted at a 90 degree angle making the tubes follow the card instead of going up above it?
i know the swiftech uses 4 holes for mounting so i was under the assumption that this could be easily roated to allow for my situation.
any info will be really helpful.
Thanks
StevenG
