GPU cooling options
1 Nov 2008
I'm just wondering what cooling options i have if ANY.
I own a pair of 470 Zotac's. What can i do with them to reduce noise and lower temps. Without voiding the 5 year warranty.
I think i know the answer, but it is worth throwing it out there.
There will be 3rd party air coolers being released very soon for the GTX 4 series.
You second option is to watercool them but that will be pricey
so removing the ref h/s will not void the warranty?
Yes i think so i know a few manufactures allow removal of the h/s not sure if Zotac are one.
If your really careful and dont break the screw threads and keep all the warranty stickers etc,you can quite easily remove the h/s and put it back later and nobody will know;)
