GPU/CPU throttling/stuttering issue.
2 Jun 2018
Here are the details for my ASUS Laptop:
CPU - Intel i5 - 7200U @2.5 GHz
RAM - 8192 MB
Intergrated Graphics - Intel HD graphics 620
Dedicated - Nvidia GeForce 940MX
The issue only occurs when I choose to run a game on the GPU (NVidia High performance processor) and does NOT occur when I choose to run the game on integrated graphics. The issue occurs every 1 minute or so in game where the fps will drop to 5 for around 20 seconds and then go back to 60fps. I am pretty sure this would constitute as throttling/stuttering.
Here are the graphs from MSI Afterburner:
https://imgur.com/a/6tEtAV7
As you can see from the graph, the throttling happened 2 times during the time recorded. The CPU jumped from 30-40% usage to 100% usage during the throttling. However, the temperature for both CPU and GPU hovers around 60-75 which I don't think is extreme.
The things I have tried so far:
- uninstalling and reinstalling the GPU driver.
- overclocking/underclocking
- lowering the settings in game (this happens even on the lowest settings for league of legends.)
- Using a cooling pad under the laptop.
Its also worth noting that is issue seems to be intermittent. When I played League yesterday on the GPU there was no throttling. But the majority of the time the issue is present.
Can anyone suggest any solution?
Thanks for reading :-)
RAM - 8192 MB
Thanks for reading :)
have you been monitoring the temps cpu+gpu ?
i would check task manager and see if resources skyrocket to 100% during these freezes, check if there is any weird app using more than it should etc. if KO
i would check power management setting pout perormance mode increase process limit to 100% (min and max), if KO
i would open the laptop and blow the dust off the cpu and gpu fans, check if KO.
i would unplug the ram, replug, clea it and run a memtest, if KO
i would restore system to a previous date where everything worked fine, if KO
and if i have windows 10, i would go to system update and at the bottom of the page you have an option to reinstall a clean windows, if still KO
to be continued...
Probably not throttling - looks more like CPU usage is killing performance and effectively bottlenecking/starving the game of resources. Throttling would be if the GPU clocks were being lowered, so check that in MSI Afterburner or similar. I would chase down what process is eating 100% of your CPU cycles and blame that.
