- 17 Jun 2012
Has my 980ti died? Went out earlier and put the machine to sleep, came back and fired up and got no response, constant boot loop but with no display.
Took the side off and the mobo debug code it gets stuck on is B2 which according to my manual is -- "console output/input devices/console initialization and load option ROM (VGA, RAID, parallel ports, serial ports) --
If I remove the GPU from the slot and reset CMOS and plug the display into the mobo it boots and works fine, if I plug in the GPU whilst windows is running it doesn't detect it or find it when I scan for hardware
Has it gone to the GPU pile in the sky?
