GPU downgrade
28 Jan 2011
Hey guys,
Im thinking of changing from a 2080 to a 2060super / 2070super.
What im wondering is do i go for the top end 2060 super or a lower end 2070?
What will the performance hit be (apart from the price)?
Whatever you could get from selling the 2080 probably would at most get a 2070S new; whereas the 2060S is just too big of a downgrade, with it being slower than even the 2070.
You might as well keep the card, unless you are desperate for cash (which you would have to go for either a 2060 or 2060S...)
Thanks for the replies guys..
I am mainly condisering the down-grade to see if i could save a little money and get a chip that is comparible with the 2080.
Such a small downgrade isn't worth it. You need to go all the way like I did, from a 1070 Ti to an RX 550 2 GB :P
The 2080 second hand, 550-600, 2070 Super - 475 - 550.
Any money saved is hardly worth the effort.....
50 quid if you're lucky.
Upgrade your downgrade for free!
Such a small downgrade isn't worth it. You need to go all the way like I did, from a 1070 Ti to an RX 550 2 GB :p
I just bought a RX570 of a ITX build! Although normally I wouldn't consider anything as lowly for myself I bought it as it was for the wife and a day ago it was only £99! (they are sold out now)
