GPU, Driver, or Game Issue?
21 Jan 2014
Fife
Been having a lot of issues with what appears to be artifacting in GTA V and was wondering if anyone could help me pinpoint exactly where the issue lies. I raised the issue in the AMD driver thread and was told by several people that it looked as if the GPU memory was on the way out and would be best to RMA the card. I had tested both of my cards pretty heavily to try and isolate the issue and realised that the artifacting was only happening on one of my cards. I have been playing the game for a couple of hours tonight on the single, working GPU and have noticed that the same issue is appearing on this card as well.
Surely my luck isn't that bad that both of my cards are about to bite the dust at the same time? Just wanting some confirmation as to where the issue is stemming from! GPU's are running at stock speeds and have no overclock whatsoever other than on the CPU. I have tried running both of the cards slightly underclocked and removed the CPU overclock, and the issue still persists.
A couple of screenshots and a video of the issue...
First screenshot is a before, second is an after.
Cheers!
First screenshots is a before, second is an after.
Cheers!
No idea what has happened here. Please delete this post!
Already tried that on both GPU's
Have you tried using DDU to uninstall and reinstall drivers? I have seen bad memory before though and it looks exactly like that though bud, so could be unlucky twice. If you have no joy after reinstalling drivers, try and nag a friend to pop one in his machine and see if it still does it.
ive had it once and only once in GTA 5 when i was doing a mission and it only came up when i turned the camera to a certain angle usually towards the sun. Id say it's the game.
