Hello, I've just replaced both fans on a GPU as one had failed. The only place I found to order the exact fans was a site that sent them from Hong Kong. The fans have arrived, they fit perfectly and I was even able to transfer the manufacturer badges on to the new fans. However, unlike the originals there is no black sleeve to protect the fan cables from the heat of the heatsink. Could anyone suggest what is likely to be the correct sleeve that will cope with sustained high heatsink temps on the OCUK site please? I am thinking I should just buy the sleeves and make ones for the fan cables so that they have exactly the same protection as the originals.
