One of my 560`s has developed a problem with one of the fans.
Upon start up it makes a noise for about 5-10 minutes, then seems to settle down, you can still hear it above the others. There is nothing externally catching on it nor does it seem to affect game play. I have checked fans speeds and temps with AB and everything seems normal.
Just wanted some thoughts from you guys. As the noise level at start up has increased over the last couple of months, is it just a faulty fan or something else to worry about.
I have got in touch with the seller and have arranged an RMA.
