- 27 Sep 2020
I was wondering about the the best way to manage the GPU fan profiles on my RX 6800XT. I have the setting in AMD software to have the zero fan below 50 degrees, but I find that in some games I find the fan kicks in really high, even though the GPU temperature does not seem to be particularly high. Not sure if its game related or due to settings?
For example Jurassic Park Evolution 2 and Homeworld Remastered seem to send the fans crazy, and Homeworld in particular would not be a game that i would expect to push the GPU that much. On this game the GPU sensor on my Kraken AIO shows 41 degrees and and fans sounded really high. I know that the Kraken CAM temps would not be exact but when I have compared to HWInfo there is usually only a few degrees in it on the CPU and GPU temps.
My previous GPU was an Nvidia and to be honest I never touched the fan profile and while the fans obviously were working when the GPU temps were hitting the high 70's, the fans did not seem to kick in quite so aggressively. I game on a 1440p monitor with the refresh rate set at 120hz. I have the AMD Chill set with Min FPS 60 and Max 120 FPS.
Is it better to set to one of the standard profiles such as Quiet or Balanced, or use a custom profile and try to smooth the fan curve a bit. I was wondering about reducing the Max Fan speed slider down from 100%, as I guess if the GPU gets too high it will throttle anyway?
