GPU Fan resistor...
22 May 2010
Minibotpc
Anyone know where i can buy one of these?
Looked online and i can only see US/China sites that sell it.
Maybe im not searching the correct name for it. I googled "pwm 4pin m to f noise speed rpm reduction gpu fan resistor cable"
Have a search for Noctua NA-SRC7, they are low noise adapters, not sure if this is what you're after?
Edit: Just noticed that you are after a mini connector...... wonder if it could be modified?
I think it can be modded with the PH2.0 mini 4 pin connector but im absolutely useless when it comes to things this small. Just don't have the steady hands for it.
Be hard pressed to find a UK seller for these. Just order from China.
Alternative is you make your own.
Think you're right, best bet is probably to order from China.
Failing all this i'm looking at alternative solutions to quieten down the fan noise atm.
  • AMP! edition cooler - If i can find one used and cheap
  • Universal Block like the EK Thermosphere
  • Kraken G12 with an AIO pump but i have limitations there (tube length needs to be adequate and must be a 120mm rad).
It's never easy but i love the challenge!
I hear you there, I'm the same with fiddly stuff, but as it's just 4 wires it might be worth a punt? Wouldn't be too costly either if you messed it up.....
@Jay85 also I've just checked in my mix-up component bits cupboard and have a few of the Noctua NA-RC7 4 pin low noise adapters lying around doing nothing.
If you want to have a try at modding them just PM me your address and I'll send you a couple for free. :)
True, pulling my hair out trying to make this gpu quieter. I'm delving into the realms of watercooling just to achieve quietness lol.
I'll keep it in mind mate, thanks for the kind gesture :).
