GPU fan speed 0% ??
31 May 2005
Hi to all I seem to have a bit of a concern, I use finalwire to monitor my overall system, recently I noticed that the GPU fan percentage remains at 0% whilst it used to report at least 40% whenever I login to my OS.
I downloaded GPU-Z which correctly detects the fan speed at 40%. Could this be a problem with the software? or maybe something else?
Thanks for your help.. Screenshot here
If GPUz is reporting it right then I'd say FinalWire isn't reading the sensor right...
Try uninstalling it, rebooting and reinstalling it - might help...
Failing that, try using Open Hardware Monitor
Does basically the same thing but looks nicer than that IMO :)
If/when you download it, on the main window, click view>show gadget
Then you go through the list of things it's monitoring and right click>show in gadget (you can rename them all too to suit what you want them to say in the gadget :) I love it!
