Hey all, looking for some help/inspiration please,
I'm fed up of having to manually change my sli'd 8800gtx's fan speeds to my liking
(or am i just lazy?
) I would use rivatuner but this only seems to work on one of the gpus and not the other.
So ideally i'd like to wire up the gpu fans to my fancontroller for easy access.
Here comes the glitch: the gpu fan connectors aren't standard size as far as i'm aware, they are four pin headers but smaller than a standard 3pin fan header.
Anyone got any suggestions as to how to get the stock fans into a standard fan header? adapters? bit of wire cutting? (i would've done this but unsure of the purpose of the four wires - I assume power, ground, control and temp monitoring, but could be wrong!)
thanks in advance
(or am i just lazy?
) I would use rivatuner but this only seems to work on one of the gpus and not the other.So ideally i'd like to wire up the gpu fans to my fancontroller for easy access.
thanks in advance
