GPU For £500 Assistance
What resolution will you be gaming (I presume you will be gaming) at? I picked up 2 x 290s for £560ish so that might give you something to think about. But if you want to go for a single car solution then the 780ti is your best option
April 2014 GPU Performance Guide
Performance Band Price Range Recommendation
1080p (Low) $99-$149 AMD Radeon R7 250X
1080p (Med) $149-$199 AMD Radeon R7 265
1080p (High) $199-$299 AMD Radeon R9 270X
1440p (Med) $299-$399 AMD Radeon R9 280X
1440p (High) $399-$679 AMD Radeon R9 290
NVIDIA GeForce GTX 780
1440p (Max) $679+ NVIDIA GeForce GTX 780 Ti
4K/Multi-Monitor (High) $1200+ 2x AMD Radeon R9 290X
AMD Radeon R9 295X2
Saw this review as i was always interested why people asked me what res i will be playing at.
How much of a difference does it really make ? Buying a card like R9 290 and running it at 1080p ?
What benefits would i get using one specifically designed for 1080p ?
A R9 290 runs 1080P as good as or better than R9 270X for example and allows you not to worry about detail settings etc, just max everything out and forget about it.
