GPU for LAN PC
Permabanned
14 Apr 2012
Hi guys what do you think my best bet is for a GPU for this case - Lian Li PC-V351B Aluminium Micro ATX Cube Case - Black
Guessing it's got to be quite short I was thinking of a used card but can't decide which, 7950? 680?
or go for the more efficient 750ti or something?
I'd also look at the 970.
Good power for it's size and also runs fairly cool so won't shove a load of heat into your case for you to deal with.
The 970 is a great choice for limited space/ventilation. If you fancy something from the red team then the R9 285 ITX is an excellent choice:
https://www.overclockers.co.uk/showproduct.php?prodid=GX-357-SP
Runs very cool and quiet, and it's absolutely tiny (I won one in the competition on OcUK a few weeks back and the card is brilliant, even able to run Just Cause 2 on almost full settings at 5760x1080!).
I would say choose whichever suits your budget/games you play.
Even something like 7770 card is going to struggle with modern games unless you knock the visuals down a good few notches.
