Ok, im looking to get a small low powered Grfx card for my HTPc but i have a couple of issues i need to work around
Issues im facing.
Case is a silverstone Milo ml02, space is a premium and it uses an included 120w itx PSu so the card has to be low powered or i need to replace the psu.
As mentiond space is very tight so has to be single slot, there is no more room for any overhang.
Ok what i need from the card
native res of my 42" Tv is only 1024x768 so the card needs to run Dead space, bioshock and other similer games at relatively pretty settings.
Must be able to do all he things current on board can in terms of audio pass through etc.
Like i said the case uses a 120w itx psu and im currently running an
asus p5n7a-vm
e5200 at stock
2x 1Gb sticks of DDr2 800mhz
1tb low powered hard drive
80Gb laptop hard drive (both sata)
Think i may be cutting the psu close but once a new card is installed power consumption will be cut by the IGp GF9300 not being used...... I hope.
I was thinking of a 9600GT but they all use external power so out of the question.
Ati cards all seem a little to power hungry so im at a loss, dont really want to upgrade the psu as the 150w version is around £60 and i dont think ill really be able to shift the old one.
So any one have any ideas?
Edit:
I have noticed that the specs for the board say hybrid sli support, would this bring any decent gain or better to replace full stop?
Issues im facing.
asus p5n7a-vm
e5200 at stock
Edit:
