GPU front sticker - Warranty question
23 May 2011
Is the Warranty effected if the front sticker on the GPU has been removed? The sticker that usually says something like the brand name and GTX470 for example?
Thanks.
Thanks.
No, Unless its a EVGA card who are completely anal about everything.
as long as the sticker isnt covering a bios changing switch (like the one on some 6990s) i would be very surprised if it did affect your warranty.
generally any sticker on any graphics card will fall off due to the massive heat being chucked out by the card. the glue on the back of stickers isnt designed to work at 80C+ for long periods of time
