GPU heat
5 Nov 2014
Hello!,
I am currently running a HD Radeon 5830 1GB.
I have had no issues with it till recently where I have been running afterburner in my games and noticed that the GPU is reaching 92C.
first off is this ok for this card? I have owned it since new back in 2011 and brought from OCUK.
I have tried the following to lower down the temps but have had no effect.
- re done thermal paste
- cleaned out GPU fan and HS
- left side of case off while gaming to see if it would lower down the temps.
but none have made any difference.
I don't want to really spend too much on sorting the issue as I want to replace it but wondered if anyone else had any ideas to try and lower down the temps.
this is my card
thanks a lot!
