GPU help me to decide !
IC3
IC3
3 Dec 2011
Hi guys need help with the decision with GPU.
Radeon HD 6970 2GB OC : http://www.overclockers.co.uk/showproduct.php?prodid=GX-123-MS&groupid=701&catid=56&subcat=1752
Radeon HD 7850 2GB : http://www.overclockers.co.uk/showproduct.php?prodid=GX-295-SP&groupid=701&catid=56&subcat=411
GTX 570 phantom : http://www.overclockers.co.uk/showproduct.php?prodid=GX-143-GW&groupid=701&catid=1914&subcat=1010
These are the card iam thinking of to go with i5 2500k and Corsair enthusiast 650w. I will OC the Card and CPU, my budget for GPU is 200 pounds.
http://www.anandtech.com/bench/Product/518?vs=549
That should help. THe 570 will give you cuda and HBAO lighting but you need to decide if that warrants the extra cash.
I would be more tempted to OC the 7850 than get the 6970. The 7850 uses less power to run and they do overclock well, on the upside all the cards you have chosen don't have reference design coolers :)
Hope the link helps
