GPU help urgent!!!
10 Mar 2012
Hey guys, I recently purchased an Asus poseidon platinum 780 to keep within my rog build and also with water cooling in mind. I had a major problem with it where one of the ports started leaking and didn't really realise until I noticed the coolant in my tube reservoir was going down. In light of this I am sending it back for either a replacement or a refund. As the card cost me around 460 quid I was wondering if there was a better option (bearing in mind the rog theme and wc). I was thinking of 2 asus 760 4gb strikers in sli or is it not worth it. Any thoughts would be appreciated.
Do you have a full watercooled setup now for the cpu/gpu, ie. all the rads & blocks etc? If so wouldn't it be best to get the card you want and get a full gpu block for it, thus allowing far greater customisation and I'm sure better temps too?
Cpu is watercooled, got 2 480 rads and obviously the poseidon is built for water cooling so don't need the extra block for it plus that card is the one I want but I just don't know how sturdy the built in wc pipe is and don't wanna have to keep going through this. Maybe it was a one off bad one.
